Author Topic: looking for w108 instrument cluster mounting hardware  (Read 6972 times)
perry113
  • USA, NY, Rensselaer
« on: July 02, 2012, 00:33:16 »
Hi.
I have a 72 280se sedan in my garage that someone else took the dash apart. I am trying to reinstall the instrument gauge cluster and there is no where in the dash to bolt it to. I must be missing 1 or more securing brackets.
Does anyone out there have these parts or can shed some light to me to getting the cluster mounted correctly.
Thank you in advance.
Peter Perry
1970 911T Bahia Red
1972 911T Albert Blau
1963 220seb coupe barn
badali
  • USA, Pa, Butler
  • 1966 230SL
Re: looking for w108 instrument cluster mounting hardware
« Reply #1 on: July 02, 2012, 10:27:11 »
There should be one bolt on the center of the back of the cluster that goes through a hole in the back center of the opening.  If the bolt is missing post a picture of what you have.  I have some clusters that are missing the instruments but the surround is still good.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
2022 GLC 300 4 Matic
perry113
« Reply #2 on: July 06, 2012, 02:13:08 »
PM sent.
I need the bracket on the back of the cluster that allows you to secure it in the dash. See. picture.
Peter Perry
1970 911T Bahia Red
scoot
  • USA, CA, Altadena
« Reply #3 on: July 06, 2012, 15:51:26 »
I had read somewhere that all 108s don't have the bracket and that it is just a friction fit with the ribbed rubber band like in a 114/115.  I don't know if that is true.   What I do know is that it's nearly impossible to get to the nut on the back of that to remove the cluster...
Scott Allen
'67 250 SL (early)
Altadena, California
badali
  • USA, Pa, Butler
  • 1966 230SL
« Reply #4 on: July 06, 2012, 16:19:49 »
The cluster has the bracket on the 108 and helps align the cluster.  It is very difficult to get the knob on the back.  Most people leave it off since it is almost a friction fit anyway.
Brad
1961 220 Sb
1966 230 SL (Sold)
2019 E 450 4 Matic
m300cab
  • USA, Pennington New Jersey
« Reply #5 on: July 08, 2012, 18:33:07 »
I've wrapped the cluster with thick double sided tape to increase the friction, works like a charm, I do not remove the tape facing out, this way it slides in easier
Michael Parlato
