Author Topic: I am now the owner of a 230sl  (Read 5195 times)
Ed Fisher
« on: June 21, 2004, 06:55:18 »
Good morning.  Well I went and did it.  The 230sl now resides in my garage, but I can tell you that I am dismayed at the incredibly large oil leak that it deposited.  This car is absolutely puking.
I cleaned the engine and undercarriage so that I can try to locate what in the heck is going on and it looks like the tach drive and maybe something near the harmonic balancer pulley, for starters.  The tach had just been repaired by the previous owner, or should I say his "mechanic", or at least someone who pretends to be a mechanic.  This car is even leaking oil onto my foot!
There is a rubber hose that is mated to what looks like the back of the instrument cluster and there is a leak back there as well.  I have never had that happen in all my years of owning/driving.  I must admit that the severity of the leaks(s) and the mess that has been made have made it difficult for me to rejoice in my purchase, at least yet.
The car pulls mightily and I can't see any smoke, however when I get the speed above 110kph there is significant smoke out of the exhaust that goes away again after coming down below that speed.  Is there an oil pressure valve somewhere that may be causing this engine to be weeping/dripping from what seems like every orifice and blowing out the exhaust at upper speeds?
There also seems to be a small coolant leak as well, but I can’t tell exactly what is going on until I am able to lay under there without soaking my shirt in a large puddle of oil.  I am looking through the search engine and the FAQ's right now, but I must admit that I need some moral/emotional support to help me through this initial shock.  By the way, the oil pressure reads pegged at anything above idle, but I don’t know if I can trust any gauges yet.
The road wandering has been remedied by placing the proper air amount in the tires.  Gee, 40psi in three and 30 in one sure made it squirrelly.  Having the tires at 32psi reduced significantly the rattles and jolts when hitting small road imperfections.
I gave it a full grease job Saturday night, however, the king pin on the drivers side would not take any grease through either the upper or lower fitting even though I removed the upper zerk fitting and verified that it was free.  Any ideas on what could be the culprit here?
I tightened the wheel bearings ever so slightly and lost that wobbly feel when moving the tire/wheel with hands at the 12 and 6 positions.  It was very slight to begin with, but now is imperceptible.  The front end is really very tight, and I must admit that the car handles quite well for 1960’s technology.  Rather tight and sporty, which is refreshing as it matches the looks of the car.
I will replace the body mount to rear diff bushing later though, since I looked in the boot/trunk and it was kind of squished.  I remember reading that it should be about a quarter of an inch and mine isn’t.  Not metal to metal either though.
So, write one and all to tell me of oil leak stories and fixes so that I can quit wrestling with whether or not to put this car on ebay and try to get my money back.  Believe it or not, this was to be a driver so that my wife and I could enjoy a convertible while the other car(s) are in phases of restoration.  I really didn’t want to devote all available hours to massaging this poor little vehicle into road-worthiness.  Actually, it is very road worthy, just not garage worthy…
Ed Fisher
P.S. Some really good news?  I crawled over and under this car with flashlight, magnet, icepick, and with my best reading glasses on and there is no rust.  I didn't think there would be, given that this is a North Texas car, but some of the postings had me worried, especially the one that said "these cars will rust on the moon".
We are hot and dry here and the cars are wonderfully well preserved.  I once took the shocks off of a 65 Mustang by merely cracking the nuts and removing them the rest of the way with my fingers.  In NE Ohio, where I grew up, shocks were removed only with a wrench that emits a blue flame.  Also, the car has never been hit, the spot welds are all perfect and the panels show no signs of work anywhere.  The horrid hood alignment is, I’m quite sure, the result of the “mechanic” and his radiator replacement.
Ed Fisher
Re: I am now the owner of a 230sl
« Reply #1 on: June 21, 2004, 07:23:36 »
Trying to post a picture.
Download Attachment: 230sl.JPG
44.12 KB
Download Attachment: DSC06428.JPG
38.26 KB
« Reply #2 on: June 21, 2004, 08:56:26 »
Hey the car looks great !
In fact its a mirror imgage of my own, same colour ,same wheels and in fact I have no front number plate either !!
As far as your oil leaks go............well I think a leakdown test is in order just to determine if you have blow by on the piston rings contributing to crank case pressure. This could force oil out everywhere !
However you could simply have a blocked breather, up there on top of the rocker cover. Take the pipe off and make sure its free. Sounds like your oil pressure pipe is leaking, that might be a pain to do but should cost much !
A friend of mine has a 66 230SL which smoked a lot and used oil but he took it on a long journey and heated it up and obviously unseized the rings. He replaced the valve stem oil seals and had no further problems !!
I hope your problems are a simple but either way if you have a rust free Pagoda your in a better position than most owners !
Enjoy !
'03 CLK Kompressor
« Reply #3 on: June 21, 2004, 10:22:08 »
Welcome to the club! Oil leaks I mean. My 280SL was always "professionally"maintained, meaning the previous owners had so much money that they didn't want to get their hands dirty. I got all the receipts:One shop replaced the front crankshaft seal, but it still leaked: They had used the wrong seal P/N. I obtained the correct part, installed it correctly and it seals.
The local mercedes shop indicated on one invoice:"Injection pump oil leak unrepairable" As it turned out, I removed the pump and tightened that bolt. No more leak.
The oil hose to the oil cooler also leaked. I replaced that as well. I have a leak under the air conditioner compressor: Can't get to it. Probably have to pull the engine. Very frustrating. It's my last leak. Drip pan, bought at Schucks, on the garage floor. But I'm driving the car now.
The automatic sucks. In the winter maybe I'll work on it some more, but now the weather is nice and I want to enjoy the open car. Changed the rear axle ratio to 3.27. Makes driving the car more enjoyable because on the freeway it now turns 3000 instead of 3800 at 63MPH.
Installed a r.h. outside mirror. Replaced the flat glass with convex. That works well! :D  I'm dreaming of installing a complete Subaru drivetrain. With the looks of that car and the running gear of my Subaru it'd be a wonderful vehicle. All Wheel Drive! :?:
1969 280SL,Signal Red, A/T, P/S, A/C, Both tops.    Ret. engr.
« Reply #4 on: June 21, 2004, 14:04:56 »
Hey Ed. Glad you took the plunge. Sorry to hear about the leaks. Mine has had a few over the years but with some work here and there they get taken care of for the most part. Good news is the parts are out there.
This is speculation but your leak inside the car combined with a probable leak where the tach cable enters the block leads me to believe your tachometer seal is shot. It is a common leak at the block but in severe cases the oil somehow makes its way up the cable and into the cab. Strange but I have heard it can happen. If you do a search here, you will get lots of good info on that problem and the tach drive in general. The only other oil in the cab would be from the oil pressure line? And now I leave you to the experts!...
Good luck.
« Reply #5 on: June 21, 2004, 14:17:51 »
Congratulations Ed. I am myself toiling at removing the last leaks after my engine rebuild. I had some coolant leak (that's fixed now, mostly it was a few hoses and the thermostat housing that needed tightening) and there is some oil on the garage floor as well. Have not figured out yet where it is coming from. Before the rebuild the engine did not leak. So it's a matter of tracing and tracking. Hang in there!, the car will give you lots of fun as well. Once they are sorted, they usually stay sorted for very long periods of time.
