Author Topic: pressure buildup in tank.....  (Read 13867 times)
gerster
Re: pressure buildup in tank.....
« Reply #25 on: July 26, 2012, 19:55:23 »
I ordered a new Tank today because of alot rust in it. Costs € 865.- here in the Netherlands.
Dave
Can't figure out fuel problem
« Reply #26 on: July 28, 2012, 20:30:03 »
Ok, back to the expert panel.  Car awakened for summer, started right up, but acted like it was out of gas.  Barely made it 1 mile ran ok at first, then sputtered going up a hill, then kept dying. Drained 12 gal. of red rusty gas.
New tank, fuel pump, and fuel fiter.  Crank and crank.  No start.
Pulled plugs - dry.
Checked outflow after pump - good.
Pump on - no fuel flows back to the tank.
Disconnected return fuel line at the front of the car near the fuel filter at the banjo bolt (is that on the dampner?) turned on pump.  When pump is on fuel dribbles out of hole where the banjo bolt was screwed in to.
Blew from banjo bolt to back near fuel tank  and from the back up to banjo bolth both ways with compressed air - nothing going through.  I put a golf tee into the line and blew from the other end to see if air would go through - nothing.
Now what?  Thanks in advance !
« Reply #27 on: July 28, 2012, 22:53:51 »
Dave you appear to have loaded this question under two headings and may need to remove this post..  Only one is needed as most people just look at "show unread posts since last visit"  and will pick it up anyway.
1972 MB 280CE Auto RHD 906G
2022 Volvo XC40 Electric
2024 Volvo EX30 Electric
Dave
« Reply #28 on: July 29, 2012, 05:42:37 »
Hello Garry
Please excuse me.  Didn't mean to that
Dave
« Reply #29 on: July 29, 2012, 06:39:16 »
No offence meant or taken Dave, just doing my morning check and cleanup
getsmart
  • Australia, Victoria, Dromana
« Reply #30 on: September 14, 2012, 22:06:09 »
Very interesting topic... :)
On my resto I've decided to try this product on my tank based on the reviews I've read (not always a good indicator but I think worth a try since its pretty cheap-at $96AUD). For those contemplating a new tank this may be a very cheaper alternative...the video is a good watch..
And I don't work for or have any affiliations with KBS Coatings  :)
I'll post my results when I'm done...
http://www.kbs-coatings.com.au/kbs-auto-fuel-tank-sealer-kit
http://www.kbs-coatings.com.au/kbs-instructional-videos
Cheers all, Joe  :)
Finding the red car
1964 230sl Restoration Project
