Please stay with me as I again raise the topic of high engine temps. I have never been happy with my engine temp climbing to 95C when highway driving. Stays at 80 when city of country driving (80km/hr). The temp will drop back to 80-85 once I get off the highway. Took the car out today to get the engine good and hot and then took some IR temp readings on the rad, inside facing the engine. This is what I got (all readings in C) across and down the rad.
inlet (top left next to battery)
86.0 85.3 84.6 83.2
83.1 65.4 76.5 81.1
79.2 70.4 66.6 70.1 (outlet, bottom right)
This seems to make sense as highest temp is next to the inlet and lower temp is at the outlet. I do not know how the cores are set up inside the rad so I am asking if the 65.4C suggests I have a partial blockage in the rad? I should also mention that my heater core is completely plugged (heater does not work obviously, another project for another day). I took temp readings on the hoses going into and out of the heater core and I got 45C and 75C respectively. Does this make sense, I figured they should be the opposite? I have read other posts about putting in a bypass and just wanted to get your thoughts on if this should drop my engine temp, considering the huge difference between the two temperatures, at least until I get the heater core fixed. I thought I would put this out for the collective to mull over before I start spending money or making modifications. Many thanks.
