Joe,
The linkage was set and worked OK before the distributor change, but I will recheck it and also try the "separating the linkage" test. With the old distributor I had to do a lot of adjustment to get the engine to run, including adding shims under the cold start valve housing. Maybe it would be a good idea to remove these again and start from scratch. I'm off to work for two days, but I'll be back.
Per G. Birkeland
69 280 sl aut 834
Norway
