I am replacing my water pump impleller/bearing unit. There are two drain holes in the housing diametrically opposed to each other, should these be positioned at the top and bottom when the unit is bolted in? It appears the fixing bolt holes on the flange would allow the housing to be bolted with the two holes in other postions.
