Please check out joining the
Emergency Contact List
for help during your travels!
Body, interior, paint, chrome, and cosmetic items
Help with underdash stuff
Topic: Help with underdash stuff (Read 3128 times)
jeblack123
Full Member
Senior
USA, GA, Albany
August 18, 2012, 20:50:33 »
At the risk of appearig ignorant to some and proving it to others, can someone tell me the purpose of the hole in the underdash panel on the driver's side (one on the passenger side as well) and the switch (button) next to it? I have a LHD 1968 280 SL Euro version automatic. Thanks again.
Full Member
Platinum
USA, CA, Solana Beach
Re: Help with underdash stuff
August 19, 2012, 06:29:03 »
The hole is there to let cold or hot air enter the foot wells on each side when the grey lever on the dash is turned to the right (down arrow):
The switch is not original. I can't help you here, you should trace the wires.
Last Edit: August 19, 2012, 06:37:01 by 66andBlue
1966 230SL automatic 334G light blue (
sold
ricrose
Reply #2 on:
August 19, 2012, 07:35:04 »
I wouldn't be suprised if a switch in that position is some kind of isolator / security switch or button. I can't see any other reason for putting one right out of sight and reach like that.
Richard
jeblack123
Full Member
Senior
USA, GA, Albany
Reply #3 on:
August 19, 2012, 10:49:28 »
Thank you both for you responses. Should there be a hose of some sort be attached to the holes to direct the air to the footwells. The PO had A/C but removed it duriong his ownership, so I am unsure of what, if anything, should be there.
james
49er
Full Member
Platinum
USA, CA, El Dorado Hills
Reply #4 on:
August 19, 2012, 13:53:34 »
No hose, just the "vent" hole.
John
1969 280SL 003820
