Author Topic: Squealing/Screeching Tire  (Read 3412 times)
taxesq
« on: August 25, 2012, 15:29:27 »
I have recently encountered a very minor issue (maybe its something more, not sure).  When I turn sharp to the right I get a squeal/screech from the front drivers side tire.  I was told this an issue with the camber, but I am not sure.  Does anyone have any idea what this could be and the remedy for it?
Thanks in advance,
Dom
Re: Squealing/Screeching Tire
« Reply #1 on: August 25, 2012, 17:49:22 »
If you keep turning left it won't make any noise. AS long as you keep turning left you will eventually find your way back home.  ;)
  I'd look at air pressure in your tires to begin with.
taxesq
« Reply #2 on: August 26, 2012, 16:40:55 »
ahaha thanks, this was my first inclination as well so I checked them and they are all at 35.
« Reply #3 on: August 26, 2012, 20:34:24 »
Is the car pulling one way or the other?
taxesq
« Reply #4 on: August 27, 2012, 01:45:34 »
very slight pull to the right
« Reply #5 on: August 27, 2012, 05:26:09 »
Sounds like you could have a problem with too much toe out.
