Author Topic: 111 window part needed  (Read 4779 times)
« on: September 07, 2012, 22:45:28 »
A friend of mine is looking for the right window lift for a 111 cab(coupe works) but it is for a electric window lift car, with the switches on the door (early type). He indicated it was a 111.025. Any leads would be appreciated.
Thanks!
Re: 111 window part needed
« Reply #1 on: September 09, 2012, 02:28:40 »
Get the old one fixed. I do it all the time. Used cab parts are rare. Electric door lifts are scarce even in the more common coupes which use the same lift as the cabs.
w113savy
« Reply #2 on: January 08, 2013, 00:57:37 »
did you still need help with your w111 item
thanks
mbzprts
Thanks!
« Reply #3 on: January 08, 2013, 03:29:14 »
Thanks for the inquiry, my mechanic friend ended up buying a parts car, and now has lots of pieces!
