Author Topic: Plastic shift pattern insert  (Read 5250 times)
tpfarm
« on: September 12, 2012, 06:02:27 »
Hi: looking to replace the plastic shift pattern insert on my  67  230 Sl automatic. Is it difficult to replace and how should I go about it.
Re: Plastic shift pattern insert
« Reply #1 on: September 12, 2012, 23:08:28 »
Use the search function, and you should be able to find the information you need. The biggest "leap" if you will, is getting the shift knob off the shifter rod. A quick blow from underneath, using a pair of protected pliers.
merrill
« Reply #2 on: September 13, 2012, 00:34:49 »
replaced mine a few years ago.
order the correct one.  I forgot where I ordered mine
remove shift knob
remove 4 bolts holding the chrome shift assy and lift off
remove plastic shift pattern insert
install new one
put it all back together.
Matt
Austin Tx
66 230 sl - "white"
78 300 D - Blue
98 C230
tpfarm
« Reply #3 on: September 13, 2012, 00:43:59 »
  Thanks , I am new to this forum and still trying to navigate around it.
w113dude
« Reply #4 on: September 13, 2012, 12:04:34 »
Try this seller on ebay, benz restorer name of the seller is Babak,  this particular one is for later models but I know he also has the earlier version which is what you need.
http://www.ebay.com/itm/MERCEDES-AUTOMATIC-FLOOR-SHIFT-GATE-W108-W109-W111-/221099852901?pt=Vintage_Car_Truck_Parts_Accessories&hash=item337a940465&vxp=mtr
johnnymack
  • USA, NH, Meredith
  • 70 280 SL Auto
« Reply #5 on: September 14, 2012, 00:29:56 »
That was the first thing I did to mine when I bought it 2 yrs ago
JohnnyMack
70 280 sl auto
