Author Topic: Make Old Rubber New Again?  (Read 10054 times)
Jkalplus1
« on: September 24, 2012, 16:39:14 »
Gents,
Has anyone ever had any success with what is explained at the following link?
http://www.ehow.com/how_8276069_soften-hard-rubber.html
Re-plasticizing old rubber?  Really?  I have some NLA rubber items that are really nice looking, but brittle and will eventually get damaged with handling and/or time.  The trunk rubber mat, for example.  Is the best one can do to keep the item clean, minimize handling, and accept it will eventually turn completely brittle and fragile, or has anyone tried re-plasticizing rubber with success?  Sounds like a myth to me...
Re: Make Old Rubber New Again?
« Reply #1 on: September 26, 2012, 00:37:06 »
That sounds like the fountain of youth!
While silicone might have immediate "feel good" results, the long term consequence is actually damaging IMHO. I use 303 on my new rubber parts but primarily for the UV protection. It contains 0% silicone which is touted by the premium brands. The cheap stuff is loaded with silicone like Armorall and others.
Rubber is a Thermoset which means that it vulcanizes or cures with heat and is an irreversible process. Thermoplastic melts with heat and doesn't cure and therefore is reversible. It might be possible to do the plasticizing technique with a thermoplastic, but I highly doubt it will have much effect on a Thermoset.
