Author Topic: Small Paint issues...  (Read 3151 times)
dwahi
« on: September 25, 2012, 10:11:34 »
Hi
In the interior of my Pagoda, I have small marks where the paint has been damaged possibly when the radio may have been removed in the past. How can I fill or repaint this without getting the whole dash repainted? Has anyone used touchup sticks or got one of those companies that may repair stone chips damage? Thanks
W113 280SL Auto 050G
Previous:
Porsche 968 Cobalt Blue (photos: http://www.flickr.com/photos/67828893@N00/tags/porsche968/)
VW GTi Mk VI
VW Jetta Mk II
Jkalplus1
Re: Small Paint issues...
« Reply #1 on: September 25, 2012, 12:25:13 »
Funny, I recently posted a thread about the same issue.  It seems the paint chip kits disappoint, the better option is to get touch up paint from MB (colour match reported to be excellent).  You apply light thin coats to build up a layer of paint up to the point where your chip is filled with paint, with just a little bit of overlap around the surrounding painted surface (to blend in).  You use light grade wet sandpaper (1000 and up) to level the surface, and then use paint polish compounds to get your gloss finish back and this should blend in nicely.  There are tutorials for this on the web. I've done it in the past and short of a complete respray, it is the only method I've tried that can give me the result I expect (no less than near-perfection).
It takes patience to do it right, but it does not require ninja skills.  Possible pitfalls: lay the paint too thick instead of multiple (5+) thin coats.  If you lay it too thick, the surface hardens, but the lower portion of your thick layer will take weeks -if not months- to dry, and you will get undesirable wrinkles in your finish.
Good luck!
Jerome
zoegrlh
  • USA, VA, Williamsburg
  • Beauty from top BCW
« Reply #2 on: September 26, 2012, 22:38:58 »
Best solution is to get dash repainted.  Should not cost that much to have done.
Robert Hyatt
Williamsburg, VA.
