Author Topic: Cold Start Valve - blocked / clogged jet  (Read 4026 times)
db180
« on: October 01, 2012, 19:15:13 »
Hi Folks,
New to this site and have searched and tried what has already been suggested, but one of the jet's on the CSV is still blocked.
Was wondering if anyone had advice or tricks/tips on what could be done to unblock it.
So far I have tried soaking in carb cleaner, pressurised air and water - still stuck. Don't really want to try heat.
Thanks in advance.
GH.
twistedtree
  • USA, MA, Gloucester
Re: Cold Start Valve - blocked / clogged jet
« Reply #1 on: October 01, 2012, 20:26:08 »
Have you blown through it backwards with air?  The next step would probably be a thin wire.
Peter Hayden
1964 MB 230SL
1970 MB 280SL
2011 BMW 550xi
« Reply #2 on: October 01, 2012, 23:40:36 »
Also try soaking it in alcohol, which works best on fuel varnish. Could rust be your problem?
db180
« Reply #3 on: October 02, 2012, 19:35:30 »
Thanks for the advice.
I've left it soaking in alcohol and see if this corrects it.
I don't think it's rust as the rest of the unit has no rust on it.
I'll update the thread if I can get it unclogged - otherwise I may just get a recon unit.
Jordan
  • Canada, ON, Jordan
« Reply #4 on: October 02, 2012, 22:41:34 »
GH, are you testing it on the car itself?  If not how are you testing it?  Thanks.
Marcus
66 230SL  Euro 4 speed
db180
« Reply #5 on: October 04, 2012, 22:08:14 »
The alcohol seems to have done the trick!
I was testing it off the car, using the method in the Tech Manual. One nozzle became unclogged with carb cleaner, then I tried the advice to use alcohol.
Fitted it back together and car fired up, eventually. I then switched it off and restarted the following evening and it started much eaiser.
Many thanks for the advice.
