Become a
Full Member
Emergency Contact List
Electrical and Instruments
removing column switch from 280 SL
Topic: removing column switch from 280 SL (Read 3028 times)
rutger kohler
Associate Member
Gold
New Zealand, Auckland, Auckland
October 08, 2012, 04:26:25 »
Hi, do I need to remove the steering wheel and horn wires before removing the column switch with turn indicator etc? An eralier post suggests you do for the 230SL but I am not sure about the 280SL
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
w113dude
Re: removing column switch from 280 SL
October 08, 2012, 12:12:45 »
The wiring is going through the steering wheel tunnel don't need to take the steering wheel off, remove side rubber, take the two screws off and undo the wiring connection from the middle of the steering column.
