Author Topic: Fuel Filter on M130  (Read 2309 times)
rson
Fuel Filter on M130
« on: October 19, 2012, 18:24:04 »
Can anyone tell me where the fuel filters for m130 motor is located. Cant seem to locate it on my car. The car is a w108 also. Any advice would be greatly appreciated. Thanks in advance
rb6667
Re: Fuel Filter on M130
« Reply #1 on: October 19, 2012, 20:07:04 »
As you are facing the motor, look just in front of the injection pump.  There you will see a round canister that houses the filter.  The filter is inside.  Make sure you use a new crush washer on the bolt that screws in through the plate on the top.   I've had good luck with copper or aluminum sealing washers in this application.
Use caution when doing this.  No electric trouble lights around gasoline!!!!   Best to do this outside using natural light.
Rb6667
