Author Topic: temp gage not working after removal???  (Read 2816 times)
erickmarciano
  • Canada, Quebec, montreal
« on: June 30, 2004, 19:32:38 »
I removed the center cluster to clean the glass and fix a few electrical problems and now the temp gage does not work. what should I look for ? is this gage all mechanical?or is there a electric part to it ?
thanks
Erick
1971 280sl
1962 VW
1954 Allstate vespa
1958 gs150 vespa
1962 gs160 vespa
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
isofast
Re: temp gage not working after removal???
« Reply #1 on: June 30, 2004, 22:02:28 »
Hi Eric maybe you can find a new gas bulb from a sedan. You may have lost some or all of the inert gas. If you stick the bulb end in a glass of hot water and the needle on the gauge does not move, my guess is you lost your gas. I hear that it is very hard to refill this gas and a new bulb and gas line gauge is needed. I forgot where, but I read somewhere a guy filled his with gas using dry ice and a very fast and steady soldering iron...sounds near impossible to me but hey I am a teamster not a chemist. :mrgreen: Ernie
I love low mile Mercedes.
1969 280 4spd Papyrus White
« Reply #2 on: June 30, 2004, 23:18:25 »
Hello Erick,
Yes that cable coming out of the temperature guage is a tiny capilary tube filled with gas. If it is bent severely it can fracture and the gas escapes. Some instrument specialists can repair these.
