Author Topic: Need a WRD - anybody know where one is?  (Read 13917 times)
Jordan
  • Canada, ON, Jordan
Re: Need a WRD - anybody know where one is?
« Reply #25 on: October 27, 2012, 17:33:28 »
If you posted a picture it would be easy to tell which one you had.  The early thermostats are about 3 inches long (70-80mm) while the later ones are much shorter, maybe an inch or so (30mm).  The early ones are extremely expensive ($700+ on e-bay) while the later ones are less than $50.  What temp water did you dip it into?
Marcus
66 230SL  Euro 4 speed
db180
« Reply #26 on: October 27, 2012, 18:42:15 »
Thanks for the response.
temperature was initially 80C which is around 176F, I did let it get upto 90C but stiil not luck.
ptooner
« Reply #27 on: October 28, 2012, 04:18:24 »
From your picture I can tell that yours is quite different from my 65 model so I will assume that mine is the "early model" and yours is the "later model".  If it is in fact available for $50 you have a very easy decision I would say.
Gerry
Jordan
« Reply #28 on: October 28, 2012, 10:34:59 »
Yes, you have the later thermometer and there are several on e-bay right now, one for as little $30.  The Classic Center also carries them as I am sure many of the parts suppliers.
Marcus
ctaylor738
  • USA, VA, Falls Church
« Reply #30 on: October 28, 2012, 14:09:12 »
Gerry -
Did you have any more success getting your slide to free up?
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
ptooner
« Reply #31 on: October 28, 2012, 23:39:37 »
Gerry -
Absolutely!  It starts and runs better than it ever has after I disassembled and cleaned and lubed the WRD.
Gerry
