Author Topic: Mercedes battery part no  (Read 11952 times)
Drewtee
  • England, Kent, Sevenoaks
« on: October 30, 2012, 11:36:27 »
Hi All,
I need to replace my battery with a Merc battery.
I rang Jacksons in the UK and they gave me the part number 000982300826 but the dimensions are too small L23.8 h 16.4 w 16.6. The battery needs to be more like 30 cm in length.
Can anyone confirm the part number for the correct battery
Its a 1971 280se. The picture below is NOT my car but the battery seems to fit nicely.
« Last Edit: October 30, 2012, 13:14:39 by Drewtee »
Andy Tee
Rhd 5 speed 728h with parchment interior
LHD Brabus - 4 speed , soon to be 5 speed.
W111 3.5 Cab and Coupe both RHD
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
Re: Mercedes battery part no
« Reply #1 on: October 30, 2012, 13:42:40 »
I recently had my battery replaced by the Mercedes dealer. The MB part number is: A 000 982 31 08. Below that are a series of other numbers: 12 V 74 Ah 680 A (EN). This was slightly larger than the previous battery but fit just fine. I hope that helps.
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
« Reply #2 on: October 30, 2012, 19:52:33 »
I bought a battery from my MB dealer and this is the number they used:
# 002 541 99 01 26
It fit perfectly for my '68 W111. I don't have the factory top frame installed, but it fit as well.
Drewtee
« Reply #3 on: October 31, 2012, 08:53:22 »
Thanks Wallace and '17beige280sl', -One of those will do the job- I think i will try the battery Wallace has first of all as i slightly prefer the look (can't believe i'm comparing the aesthetics of two batteries!
Andy Tee
« Reply #4 on: October 31, 2012, 20:13:46 »
The 3.5 had the battery in a different location and may not be the same size. I will measure mine tonight and see what it is. I removed the two pull straps on the side because they just looked cluttered to me.
heckflosse
« Reply #5 on: November 01, 2012, 13:47:14 »
Well, there is a small issue here, your MB dealer provides you with white batteries these days, but when these cars were new the batteries where black, and
they where delivered from Bosch. http://www.bannerbatterien.com/banner/home/index_en.php deliver batteries with the right measurements and
if you tear off the Banner stickers and replace them with a Bosch sticker, witch you will find on ebay i would suppose you are up to the "originalgefühl"..
With the Banner battery mounted you will also be able to use the original mounting top frame. The 3.5 has the battery mounted on the other side of the
engine bay, and it is also bigger than the one for the straight six cars. But also the correct 3.5 battery can be delivered from Banner..
Here is the engine bay of my 280SE/Ca with this battery mounted:
« Last Edit: November 01, 2012, 13:54:01 by heckflosse »
« Reply #6 on: November 01, 2012, 15:30:16 »
Very true about the current white batteries. In the US for MB concours judging the white battery is considered as acceptable, with no impact on scoring. There are some places in the States that do reproduction batteries as Jan mention for Europe. One such place is Antique Auto Batteries in Hudson Ohio -  from their web site - "We offer Correct, Maintenance Free - "No Judge Will Know" Batteries " I never tried to source a Pagoda battery from them, is use the current white MB Varta battery.
