Author Topic: Rear shock help  (Read 15445 times)
Rear shock help
« on: July 03, 2004, 07:35:29 »
Hi and help!
Has anyone recently installed rear Bilsteins? I am about to but cannot figure out the instructions re: the order and orientation of the rubber & washers. None of the examples seem to match the parts that came with.
Unfortunately, the ones coming out are not Bilsteins so I can't use them as a guide.
Thanks. (and any specifics/pics would be greatly appreciated!)
Re: Rear shock help
« Reply #1 on: July 03, 2004, 17:39:36 »
James.
I just ordered Bilsteins for my 280SL. It should be a fairly streight forward job. Whatseems to be the problem?
Re: Rear shock help
« Reply #2 on: July 03, 2004, 20:40:53 »
Hey Bob.
I too am under the impression it is a pretty straight-forward job for the average Joe. (Which of course means it will be next to impossible for me...)
I haven't started taking old ones out yet -- just wanted to study the shocks and the order of the parts that will go in. The problem is I find the information sheet that came with them totally confusing. It basically has every configuration of every shock type but with no specifics to 113s. Nor do the pictures seem to match the kit included. Its in German as well, but that part I can usually get around. So I thought if anyone has recently figured it out, they could share the secret code... Good luck with yours and please post if you understand it all.
Re: Rear shock help
« Reply #3 on: July 05, 2004, 15:42:56 »
Hello james,
Start by placing one of the washers on the shock shaft. If you look at the washer it has a recess which fits over the snap ring on the shock shaft. Make sure the recess side of the washer is down on the snap ring. Next add rubber grommet, then install the rubber cover. Now install the top of the shock in the car. Once the shock top is in place add a rubber bushing and a washer. Cup the washer up this time. Now install one of the wider nuts. Next you can go under the car and compress the shock and slide it on the mounting shaft on the rear axle. Use a little silicone grease, vasaline, or a bit of auto transmission fluid on the shaft to help the shock slide on. Regular grease is not good for the rubber. After fastening the shock below, go to the shock top and tighten up the 17mm nut until the shock shaft begins to turn. At this point the nut should be bottomed out. Those wratcheting box end wrenches work great here. Next tighten the second skinnier nut to lock both in place.
The fronts can be a bit more difficult. One thing I do is to compress the shock with the rubber boot installed and use a water hose clamp  around the rubber boot to keep the shock copressed until it is in place. Once the bottom of the shock is in place, loosen the hose clamp and guide the shock shaft into it's mounting hole. Don't miss,  the end of the shock shaft can push a dent into the fender from below!
Let us know how it feels with the new Bilstiens, I think you,ll be pleased.
« Last Edit: July 05, 2004, 15:47:38 by ja17 »
Re: Rear shock help
« Reply #4 on: July 05, 2004, 19:03:32 »
Hi Joe. I just about understand your instructions (the "just about" is on my end not yours...)
The shock already has the equivilent of an upfacing cup washer on it. Is this the one you suggested I start with? or should another washer go next?
Then I get that I place a rubber donut next. Here is another snag. The kit came with two rubber guys, one is a bit larger and more like the sway  bar bushing. The other smaller one is more rounded at the top. So which do ya suppose goes on before the shock goes in place?
Next, the new shock did not have a dust sleeve, and the old one does not either? Safe to not use one?
Once shock is in place, I understand that another rubber bushing goes next, then upward facing cup washer ... then the lock nut that came with new shock. (there is only one, but old one has a second ...)
Sorry to be so dense -- just want to be sure...
PS. Until this time, I thought you got to top of the shock from trunk. I now see that there are access holes in the soft-top boot...
Re: Rear shock help
« Reply #5 on: July 05, 2004, 22:53:04 »
Hello James,
The washer that is already on the shock should be the right one to start with. If you look closely at the bottom of this washer where it meets the shaft you'll see the snap ring seated in a small recess in the bottom of the washer. The large rubber grommet goes on first. A dust cover is not always used on rear shocks now that you  mention it. the fronts will have the dust cover. These new shocks may have one lself-locking nut only? If so one nut is fine. If it is a locking nut you will have to hold the little flattened end of the shaft while tightening the nut because the shaft will try to spin.
These are very good questions. Don't hesitate to ask. If you are taking non factory parts off or the design has changed, you have nothing to go by.
« Last Edit: July 05, 2004, 22:54:53 by ja17 »
Re: Rear shock help
« Reply #6 on: July 06, 2004, 10:53:09 »
Thanks Joe, Bob, Jeff, (George) and others. This has been very helpful. As soon as I have 5.5 hours free, I will tackle this 1.5 hour job...
« Last Edit: July 06, 2004, 11:01:31 by J. Huber »
Joe
  • USA, CO, Colorado Springs
Re: Rear shock help
« Reply #7 on: July 06, 2004, 13:51:34 »
Hello, James,
I just did this job this morning, and will pass on what I learned. I replaced Bilstein with Bilstein, which doesn't mean the old ones were on correctly, but the following instructions are based on how the parts on the old shocks were arranged:
1. There are three washers supplied with the new shock. The largest one goes on the top and the other two on the bottom.
2. There are two rubber doughnuts supplied. The smaller one looks like an angel food cake, and it goes right on top of the flanged washer that is already on the shock. The round side of the cake goes up.
3. To remove the old shocks, remove the nuts on the top before jacking up the car. The pressure makes it easier to take off the nuts without the shock shaft turning.
4. After these nuts are off, jack up the car until the wheel is almost off the ground. Then remove the 17mm bolt holding the bottom of the shock on.
5. Prise the bottom off. I used the all-purpose handle on my socket rachet.
6. After putting the smaller rubber doughnut on the top of the shaft, put the top  of the shaft through the upper hole. Mine (230sl) exits in the trunk, but yours may be different.
7. Now slip the bottom on the bolt holder. Mine didn't need any lubricant, but it may help.
8. Put on the middle-size washer. It should fit just over the bolt holder.
9. Put on the smallest washer. The cupped side will go over the end of the bolt holder.
10. Put on the bolt holding the bottom of the shaft and tighten up. I didn't use a new lockwasher here, but you may want to.
11. Let the jack down. This will put pressure on the shock.
12. Put the larger doughnut on the top. Follow it with the flanged washer, cupped up. I don't know why the big deal on which way the washer should be cupped, but that is how my old one came off. When I say cupped up, I mean like it would hold water.
13. Now put on the nut and tighten it. I had to use a 6mm wrench to hold the shock shaft since the new nut is a locknut. The nut will bottom out.
14. You're done. You'll probably be hungry now, after dealing with doughnuts and cakes!
The whole job took me about 35 minutes. Easy, and almost no chance of bloodshed. Joe Alexander furnished enough instructions to help me, but I thought some additional details might be useful.
Joe2
Re: Rear shock help
« Reply #8 on: July 06, 2004, 16:35:11 »
Hello Joe (from the other Joe),
You forgot one thing! How does the car drive now?
Re: Rear shock help
« Reply #9 on: July 07, 2004, 15:18:46 »
Wow! Thank you Joe #2 as well. That was the perfect play-by-play I needed to get started. Hopefully get to them this weekend.
Joe
Re: Rear shock help
« Reply #10 on: July 07, 2004, 21:11:44 »
I tried the car today, and it is noticably more stable at speed with the new shocks on the rear. Now I think I can take it over 120. I was nervous going that fast before, because the car just did not feel like it was tracking right.
Tomorrow we're taking off for Santa Fe in the 113. It's a 300-mile drive, one way, and this will certainly be a test of my mechanical skills. I did join AAA today, with the "plus" membership. That gives me 100 miles of free towing. I also bought some seatbelts to put in. They came from a 1965 Wildcat; right vintage, anyway.
I'll give the group a shout next week on the outcome of this trip. I feel like a young bird that is just leaving the nest for the first time. Now to tell the wifey the plan!
Joe2
1965 Euro 4-spd
Re: Rear shock help
« Reply #11 on: July 11, 2004, 15:26:07 »
Help! Well, I just went to do shocks... Old one came off easy enough. Problem began when trying to get new bottom section on. It would not go despite ATF and lots of repositioning & banging with mallet, wood, etc.
In fact, I got a little forced on -- and whole bushing came out of shock. [:(!].. regrouped and took a look. Here's the rub: the new hole in bottom bushing is 5/8. The sleeve on bolt holder and old bushing hole both 3/4" And I am afraid the twain shall never meet. Any ideas?
One thought -- could the sleeve I see on the shock mount have been added. It seems connected but I am really stuck here.
PS Old shock is really shot (it is at least 25 years old and is a Monroe from belgium). Anyway, I may have to punt again and put the piece of crud back in.
Re: Rear shock help
« Reply #12 on: July 11, 2004, 21:21:48 »
Hello James,
Your discovery rings a bell. A sleeve is installed on the mount as an adapter to make some non metric aftermarket shocks fit. Take some wd40 and some vice grips and give them a twist they should come off.
« Last Edit: July 11, 2004, 21:24:00 by ja17 »
Re: Rear shock help
« Reply #13 on: July 11, 2004, 21:47:08 »
Very encouraging Joe. I will give that a try tomorrow. I went ahead and put old shock back on (because I hate seeing the car all twisted and jacked up ... looks like it hurts.) I think I can now get it off in minutes.
Speaking of which -- what is the best way to jack up the car when I do rear shocks? I used the frame near rear jack hole but was a bit worried. You may recall my rust issues. I also put a stand under the axle.
Would jacking from the thrust arm be better? Thanks again.
« Last Edit: July 11, 2004, 21:48:43 by J. Huber »
Re: Rear shock help
« Reply #14 on: July 11, 2004, 22:47:53 »
Hello James,
You can jack the car directly under the differential. A good strong place to set the jack stands is under the  trust arm mounting points on the chasis. You then can use the jack to adjust the swing axles up and down for shock installation. Try to keep the jack somewhere under the car as an added safety while on jack stands.
You can move each swing axle up and down after placing the jack under the point where the trust arm attaches to the swing axle.
Be careful not to let the right swing axle bang down when unhooking the rear shock.
The shock limits the downward travel of the swing axle. Allowing the right swing axle to drop downward can damage the differential casting. Lower it gently
Re: Rear shock help
« Reply #15 on: July 16, 2004, 22:47:38 »
Well, I am back. And the news is not all that good. A few of you have followed my progress off-line but here it is for the whole world..
At last post, I was going to see if there was an added sleeve on my lower shock mount because it seems way to large for the Bilstein bushing. I removed the old shocks again and had a look. It may be a sleeve but it ain't budging. I tried penetrating oil, twisting & pulling with V-grips ... not moving. So back to square one.
Has anyone who has put on rear Bilsteins ever had this kind of problem? Also, my pivot post that the shock slides on is a female end -- and takes a 17mm head bolt. Is this like anyone elses?
Thanks.
Re: Rear shock help
« Reply #16 on: July 17, 2004, 05:57:53 »
Hello James,
I will measure the diameter of one here today so we can determine if you really do have a sleeve on it. Yes it is a 17mm bolt head with a cup washer and a flat washer. will be back soon!
graphic66
Re: Rear shock help
« Reply #17 on: July 17, 2004, 06:40:43 »
Just a thought, maybee the metal bushing from the shock is siezed on the mounting bolt and has separated from the rubber bushing on the shock it was fused to. Check your old shock when you take it off to see if the bolt hole has a steel sleeve in it or is just rubber. I have seen shocks that after being on a long time separate like that and the only way to get off the sleeve is with a torch. On my Unimog I had to actually cut the sleeve off with a torch. Just use the cutting torch to slowly cut the bushing away from the mounting stud. It may not appear to be a sleeve on the mounting bolt if it is really siezed up. Again check your shock when you take it off for the metal sleeve, if the hole is just rubber your sleeve is probably siezed on the mounting stud. Also only a Oxy/Acetylene torch will heat it enough to do anything. Propane or Map is somewhat useless in getting metal red hot in this situation.
Re: Rear shock help
« Reply #18 on: July 17, 2004, 23:27:00 »
Hello James,
I measured the shock mounting shaft at the rear axle and found that it is 16.5 mm.  diameter. Measure yours to make sure there is realy  bushing on the shaft first. If a bushing is on the shaft try taping it. You may be able to use a pipe wrench to rotate it off?
Keep us up to date.
Re: Rear shock help
« Reply #19 on: July 18, 2004, 17:36:45 »
Thanks Joe. Well that tells me something. My diameter is more like 19mm. And just enough over to keep me from forcing the bushing on.
If it is a sleeve it is sure well attached (perhaps 27 plus years of wear). A few of you have suggested using heat. I am not wild about laying on my back under my 40 year old gas tank with a acetylene torch ablaze -- so I may take it into a shop. (Unless it miraculously loosens up).
One thing I have confirmed. The shocks are shot. They have no resistance. I can just pull the rod in and out... I look forward to the new ones!
Re: Rear shock help
« Reply #20 on: October 10, 2004, 16:24:40 »
Finally have closure on this here thread. To refresh -- in attempt to change rear shocks, the shock mount shafts were too large to fit my new Bilsteins. Joe A. and others concluded there could be an added sleeve on there for aftermarket shocks. If true, they didn't want to budge so I was stuck...
Well, at last I decided to take the car into the shop. Sure enough the sleeves were rusted on. The final solution was to carefully heat them up. Bingo! Off came the sleeves and on went the new shocks -- (together with front shocks, engine mounts, and subframe mounts). Needless to say, I am thrilled!
Thanks to everyone who pitched in.
Re: Rear shock help
« Reply #21 on: October 11, 2004, 02:20:33 »
So James......tell us how it feels on the road now ??
'03 CLK Kompressor
Re: Rear shock help
« Reply #22 on: October 11, 2004, 09:07:54 »
Well, Ben, this could second as my answer to the "what puts a smile on your face?" thread...
The car handles great! The car has always steered pretty well but was sort of scary around curves. Now it holds the road much tighter. More specific to the rear shocks, I used to get a sideways slide over rough roads, now it stays straight and absorbs them much better. I recommend updating suspension parts to anyone who has yet to do it.
Re: Rear shock help
« Reply #23 on: October 12, 2004, 04:37:02 »
......funny you should mention that. Lately mine has developed a tendency to shimmy quite a bit at the rear, like its nervous. It seems like it was a sudden deterioration though but I dont see anything broken or obviously worn ..........apart from everything that is !!
'03 CLK Kompressor
Re: Rear shock help
« Reply #24 on: October 15, 2004, 11:22:03 »
Originally posted by J. Huber
Finally have closure on this here thread. To refresh ....
James,
Thank you so much for following up on this.  I see so many threads that never have a resolution posted.  Thanks!   :D
