Author Topic: Where to splice into the 4 parking lights?  (Read 3949 times)
awolff280sl
  • USA, FL, Sarasota
« on: November 26, 2012, 22:51:39 »
I am installing a central door locking system which uses a relay to flash the headlights upon locking and unlocking. Can someone give me an idea or two as to where I can (conveniently) splice into the leads to the 4 parking lights, i.e. under the dash off the light switch, fuse box, etc. Thanks
« Last Edit: November 27, 2012, 03:30:55 by awolff280sl »
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Larry & Norma
Re: Where to splice into the 4 parking lights?
« Reply #1 on: November 27, 2012, 10:09:50 »
In the UK it is more common to flash the direction indicator lights. There is a connector behind or just above the kick panel on
the passenger side (RHD car) where the loom for the rear lights is.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
awolff280sl
  • USA, FL, Sarasota
« Reply #2 on: November 27, 2012, 14:13:47 »
thanks Larry and/or Norma. I am familiar with the plug connection for the rear light wiring harness, and flashing the direction indicator lights would be fine. However, I would also want to incorporate the left and right FRONT turn signal lights as well.
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Larry & Norma
« Reply #3 on: November 27, 2012, 14:34:43 »
The front and rear indicator lights are connected together so tapping into say 'right rear' will also operate 'right front'.
They are electrically connected.
2023 Ioniq6
2005 C230
awolff280sl
  • USA, FL, Sarasota
« Reply #4 on: November 27, 2012, 15:41:22 »
you are entirely correct: left=black-white, right=black-green
thank you very much
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
