Author Topic: engine bay satin or gloss  (Read 20342 times)
hkollan
  • Spain, Castilla-La Mancha
Re: engine bay satin or gloss
« Reply #25 on: August 08, 2014, 05:41:05 »
Hi Rob,
The pictures of the original engine bays I believe you are referring to, does not show the rubber plugs because they are painted, but because there are no rubber plugs in the inner fender sidewall on the earlier 280s. But if your car has them, they where as you noticed, originally painted. No 230 or 250's ever had those holes/ plugs. Trying to adjust to the judges detailed knowledge or lack thereof will be impossible.
I agree with Gael, be confident and do it the way you know is original and correct way.
Hans
Hans K, Cuenca, Spain
« Reply #26 on: August 08, 2014, 07:26:39 »
The engine bay paint should be the same paint as everywhere else.
garymand
  • USA, CA, Meadow Vista
« Reply #27 on: August 08, 2014, 19:34:50 »
I sure hope this settles it:  same paint all over.
Gary
RobSirg
« Reply #28 on: August 10, 2014, 13:02:26 »
Thanks All,
I will spray the plugs but I might spray them outside of the car - for several reasons :
1) So if they are removed they wont peel off paint.
2) So the edge of the hole is painted also
3) In case I don't like - I can remove the paint from the plug or simply buy new plugs :)
Cheers
1962 E Type Jag BRG with Tan
1974 White Alfa Spider 2000
2023 Range Rover
1982 280TE (my daily)
1977 Yellow 911 Targa
1991 Nissan Figaro
1959 190SL Black
1970 300SEL 3.5
49er
  • USA, CA, El Dorado Hills
« Reply #29 on: August 10, 2014, 16:05:57 »
Hi rob,
 Sorry I did not reply earlier. As others have mentioned, earlier 280s did not have the holes/rubber plug in the fenders which accounts for mine not having them. I am not able to check my car right away but I do seem to recollect that there are rubber grommets in the engine bay that might be painted. I will check and let you know in a few weeks.
John
1969 280SL 003820
garymand
« Reply #30 on: August 11, 2014, 17:17:13 »
I may be very difficult to put painted plugs in the holes without cracking the paint on the plugs.  Maybe 2 steps paint the hole, insert the plug, paint again.  Good point below, degrease and prep the bubber befor painting.
« Last Edit: August 12, 2014, 18:50:21 by garymand »
Gary
« Reply #31 on: August 12, 2014, 04:50:35 »
Tom Colitt addressed the issue of the plugs being painted where fitted a few years ago when he examined a low mile original that was taken apart for painting. the plugs were apparently painted in place and due to the rubber being covered with release agent from molding it would appear that most of the paint has fallen off over time. I didn't go over the post again but I do recall some photographs of the rings of primer around the holes where the plugs were installed as evidence.
See the third paragraph:
http://sl113.org/forums/index.php?topic=6318
