I have done it, you need a dermal tool and about half hour of time, you basically have to grind off the inner lip inside the bezel , then putting it back (I'm assuming after re-chroming the bezel) would be the reverse using very small amount of clear silicone for adhesive at the lip where it makes contact to the bezel.
