Author Topic: Low fuel warning light - 1964 230SL  (Read 4871 times)
relbhcb
« on: December 23, 2012, 08:16:51 »
Did the (UK spec) early 230SL have a low fuel warning light? Mine doesn't seem to, but perhaps a bulb has gone? The gauge works - in a fashion - but I am currently having to reset the trip meter each time I fill up to judge when to fill up again.
TIA.
Paul & Dolly
  • i Car
Re: Low fuel warning light - 1964 230SL
« Reply #1 on: December 23, 2012, 10:22:10 »
The circuit diagram seems to show one (10c fuel reserve warning)
Paul
Mitsubishi i Car
Toyota RAV 4  Hybrid AWD
paults1
  • USA, FL, The Villages
« Reply #2 on: December 23, 2012, 13:28:27 »
My '63 230sl has the low fuel warning light.
relbhcb
« Reply #3 on: December 23, 2012, 13:56:29 »
Quote
Thanks Paul. Can I ask where on the dashboard the light is?
« Reply #4 on: December 23, 2012, 15:58:32 »
Hello. It is a small square (red when lit) at the bottom of the fuel gauge. Are you certain you have run low enough to activate? Its scary to find out -- but I had same concern... Until it came on! Usually with 1-2 gallons left. Good luck.
relbhcb
« Reply #5 on: December 23, 2012, 19:32:38 »
James - thanks for that; I am truly embarrassed to admit to it, but it could well be that I have never let the tank empty sufficiently for the light to come on. (I have only had the car for a couple of months). Now that I re-look at this photo, presumably the red "dot" is the light?
I'll put a plastic petrol can in the boot (/trunk) and let the tank get lower to see if it works ...
Julian
relbhcb
« Reply #6 on: February 06, 2013, 18:48:16 »
An update; having syphoned out some fuel I can confirm that my light does indeed work, and seems to come on with about 7-8 litres of fuel remaining. It would have been nice if it came on _slightly_ earlier, but at least I now know it works! Thanks all.
