Author Topic: Headrest clips  (Read 3756 times)
450sl
Headrest clips
« on: December 29, 2012, 12:34:36 »
Hi all,
Can anyone tell me what the use is of the round clips on the attached picture?
Mark
w113dude
Re: Headrest clips
« Reply #1 on: December 29, 2012, 13:26:17 »
It appears to be an access hole to the connecting bars, I guess you can loosen or tighten them as needed.
Re: Headrest clips
« Reply #2 on: December 29, 2012, 17:32:21 »
Yes, you can access a small bolt inside the headrest to tighten or loosen them as needed to hold position.
Nate
  • Mill Valley, California
Re: Headrest clips
« Reply #3 on: December 30, 2012, 03:37:27 »
Leverage for pulling the headrests up. Also may be for a tighter more uniform fit of leather or mb tex over the headrests.
Arabian Gray / Dark Red Leather
2013 Porsche 911 Carrera 4S Coupe
Black on Black
2013 ML350 4MATIC
Arctic White on Almond Beige
Wife's car that I get to drive
1964 Porsche 356C Coupe
Irish Green on Black
Black Plate CA Car
Unrestored
450sl
Re: Headrest clips
« Reply #4 on: January 01, 2013, 10:18:50 »
Happy New Year Guys ! ; may i conclude  that the only disadvantage of not putting them into my new covers is not having fast adjustment access ?
hkollan
  • Spain, Castilla-La Mancha
Re: Headrest clips
« Reply #5 on: January 01, 2013, 23:26:58 »
If your headrest previously  had the holes to access the 10 mm hex bolts, not adding the holes will only leave the option to remove the covers to access the adjustment screws when they eventually need  tightening.
In addition to that you will loose the original appearance without theese holes and corresponding plastic inserts.
Hans
Hans K, Cuenca, Spain
