Author Topic: Cross over linkage  (Read 3366 times)
friendofaustria
Cross over linkage
« on: January 08, 2013, 18:44:11 »
Hi everyone,
can someone please give me a guideline how to remove  passanger side bracket (can be pivoted, has brass ball) of the cross over linkage. I need to get this off to be able to remove the all the removable parts for "yellow zink" job.
I have attached a pic.
thx
Gerhard
66 230sl
Re: Cross over linkage
« Reply #1 on: January 09, 2013, 18:26:29 »
There's a roll pin that you will need to remove first before you can remove the lever on the pump end of the shaft. The bracket with its bearing will slide off the shaft after that.
friendofaustria
« Reply #2 on: January 09, 2013, 19:52:29 »
thank you, but I'm looking for the bracket on the opposite side to remove as marked on my picture.
thx
Gerhard
« Reply #3 on: January 09, 2013, 23:55:11 »
As you can see, I don't always look at the pictures. :-[
The shaft should simply pop out of the bracket. There's a heim type bushing on the shaft that's held in place with an E clip. When you're ready to install, just give it a good push and the bushing will pop back into place.
friendofaustria
« Reply #4 on: January 10, 2013, 02:27:58 »
thanks a lot.  I will try tomorrow
thx
Gerhard
