Author Topic: Penetrating Oils  (Read 4845 times)
69280sl
  • USA, IL, Elk Grove
Penetrating Oils
« on: January 10, 2013, 16:30:19 »
Someone with a lot of spare time did a comparison test and sent the results to Machinist's Workbench magazine. From worst to best WD-40, PB Blaster, Liquid Wrench, Kano Kroil. Liquid Wrench was "almost" as good as Kroil at 20% of the cost.
Surprising news, a home made concoction of equal parts ATF and acetone was the best by far. It broke a "scientifically" rusted connection with 1/2 the torque required by Kroil, and 10% of the torque required without any oil.
As with anything found on the internet, consider carefully.
Gus
Gus
Re: Penetrating Oils
« Reply #1 on: January 10, 2013, 18:15:06 »
What's funny about this, Gus, is that this same post has been around all car forums for a few years now.  Do a search and you'll find it everywhere!  Everybody has their opinions...nobody has produced the article!
I'd offer that if there is any truth to the Acetone/ATF mix, it is easy enough and cheap enough to try.  I'd just be a bit concerned about getting acetone on anything plastic, rubber or painted in or around your car...
ejboyd5
  • Southold, NY
« Reply #2 on: January 11, 2013, 12:38:31 »
My link to the article now appears as "broken," so the search for the original document continues.
« Last Edit: January 11, 2013, 12:44:44 by ejboyd5 »
