Author Topic: Engine block drain plug and washer  (Read 2595 times)
awolff280sl
  • USA, FL, Sarasota
« on: January 14, 2013, 13:35:08 »
does anyone know the part numbers for the 19mm drain plug and washer located on the right side of the engine block?
« Last Edit: January 14, 2013, 13:59:49 by awolff280sl »
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
Jordan
  • Canada, ON, Jordan
Re: Engine block drain plug and washer
« Reply #1 on: January 14, 2013, 15:03:49 »
Are you referring to the coolant drain plug?  If so there is no part number for the hex head screw, M14x1.5x12 (DIN 961-8G) is what I have in my book.  The seal ring is 636 997 02 44.
Marcus
66 230SL  Euro 4 speed
awolff280sl
  • USA, FL, Sarasota
« Reply #2 on: January 14, 2013, 23:14:31 »
THANKS! It is the coolant drain plug that takes a 19mm wrench.
« Last Edit: January 14, 2013, 23:19:08 by awolff280sl »
Andy   Sarasota, FL
'69 280SL 4speed
'06 Mitsubishi Evo
