Author Topic: Pinion Seal Replacement - holding the pinion shaft  (Read 2393 times)
ctaylor738
  • USA, VA, Falls Church
« on: January 26, 2013, 17:38:20 »
I replaced the pinion seal in my 280 project yesterday.  Not having the holding spanner 111 589 02 07 00, I came up with this arrangement to keep the pinion from turning while I loosened and tightenend the slotted nut.  It's a 10 mm bolt with three nuts.  Two secure the bolt to the flange and the third butts up against one of the bolt heads on the cover.  To tighten, I just moved the flange so that the third nut was against the bolt head below (obscured by brake cable).
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
w113dude
Re: Pinion Seal Replacement - holding the pinion shaft
« Reply #1 on: January 26, 2013, 17:50:23 »
It's genius Chuck! this would have come very handy last week.
