Author Topic: Booster vacuum line PN?  (Read 3206 times)
ctaylor738
  • USA, VA, Falls Church
« on: January 28, 2013, 16:45:42 »
Does anyone know the PN for the newer-style clear brake booster vacuum line?  The EPC shows only the older fabric line with the in-line water trap which is NLA but no replacement is specified.
Both the booster and the intake manifold have 15 mm male fittings
This is for my 280SL project - getting close to starting!
TIA
Chuck Taylor
1963 230SL #00133
1966 230SL #15274 (sold)
1970 280SL #14076 (sold)
Falls Church VA
Re: Booster vacuum line PN?
« Reply #1 on: January 29, 2013, 11:24:46 »
000 435 2182 ?
Naj
« Reply #2 on: January 30, 2013, 00:23:22 »
Chuck did you check the SLS site? They had two listed (11343000629 - with designation T52, 1084301929 - 280 SL 006619>0135???) but they indicated they were not able to get them. Perhaps a numbers cross check with MB would help??
ctaylor738
« Reply #3 on: January 30, 2013, 02:18:59 »
Thanks for checking.  I did not look at the SLS site.
I ended up having the dealer parts guy chase it, and they also came up with 113 430 06 29, which arrived this morning from the warehouse in Robinville NJ for $54.96 list.  Not sure why SLS can't get it.  I put it on and it seems to fit but it could use a 90 degree fitting on the intake side instead of the 45 degree that it came with.
Chuck Taylor
1963 230SL #00133
Falls Church VA
