Author Topic: 1966 230SL Speedometer  (Read 3528 times)
Harry
  • USA, TN, Knoxville
« on: January 28, 2013, 18:20:02 »
I have the Speedo, Instrument Cluster and Tach out of this car and would like to remove the glass front on the Speedo to clean the glass.  The Cluster and Tach are nice and clean but the Speedo has a film of some kind of light film on the inside.  I think I did this on a 190Sl many years ago but I thought I'd ask about other's experience before doing this on the 230SL.  I didn't see anyhting in searching the forum that addressed this (although I may have missed it).
Harry
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
Re: 1966 230SL Speedometer
« Reply #1 on: January 28, 2013, 18:52:02 »
This has been discussed, use the search function, and use "speedometer glass" as the criteria. Don't limit by the topic. There should be a single page of results.
KevinC
« Reply #2 on: January 28, 2013, 19:00:47 »
You'll also find good detail by just typing in "cluster" into the search function.
Harry
« Reply #3 on: January 28, 2013, 21:11:33 »
Thanks.  The described search approaches did yield some results.  I'll continue to go through similar searches.  Very much appreciated - Harry.
Harry Bailey
Knoxville, TN
1966 230SL
Automatic
KevinC
« Reply #4 on: January 29, 2013, 02:25:39 »
Harry,
If you get stuck, make sure to post again.
Kevin
