Author Topic: Fouled spark plugs problem  (Read 2996 times)
natenate
« on: February 12, 2013, 08:58:07 »
1967 230sl
Hi
The spark plugs are getting fouled (black carbon) very quickly seems that I have a fuel problem. Not sure what my first step should be with addressing the problem. Any advise would be a great help.
w113dude
Re: Fouled spark plugs problem
« Reply #1 on: February 12, 2013, 12:45:27 »
I would make sure the linkage on the top is correct to stat with, this will make sure your air/fuel ratio is correct put new plugs in and try, it could also be weak coil, bad wires or plugs.
Richard116e
« Reply #2 on: February 12, 2013, 13:04:09 »
Hi
It could be just that you just need to take the car on a long run.  Starting up for short period of times  for example in the garage over winter can foul up the plugs.  This could be a starting point to looking at the problem.
Thanks Richard
« Reply #3 on: February 12, 2013, 23:41:36 »
The "WRD" is another item to check early in the quest.  If it is stuck, you can have a very rich running condition. Give us some history and ask more questions.
