Author Topic: Fitting a new Softop  (Read 3702 times)
Khurram Darugar
« on: February 21, 2013, 09:15:21 »
Gents,
My softop, frame and all, is out of the car and ive just recieved a new one from GAHH.
On a scale of 1-10 how difficult is it to replace the softop?  Is this a job better suited to the experts.... ?
Id like to avoid the situation where im worse off then when i started.
Kay
« Last Edit: February 21, 2013, 10:13:27 by Khurram Darugar »
Re: Fitting a new Softop
« Reply #1 on: February 21, 2013, 10:33:14 »
For information and a step by step, look at our Technical Manual
http://www.sl113.org/wiki/Tops/SoftTop
Richard M, NYC
Larry & Norma
« Reply #2 on: February 21, 2013, 10:56:42 »
Did mine a couple of years ago, not too bad a job. MUST be done in warm weather as the
top will be more pliable and stretch easier. It will be tight when first fitted but will stretch in time.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
Khurram Darugar
« Reply #3 on: February 21, 2013, 13:27:39 »
Thanks Larry, that tells me that i can do it too!
Happy Motoring
Kay
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #4 on: February 21, 2013, 14:07:08 »
Having replaced my soft top this fall, don't forget to stretch the top by setting your car in the sun with the top up, Wrap a brick in a cloth and set it between supports. The sun, combined with the weight of the brick, relaxes the top and makes the world of difference when you're trying to latch the back of the soft top. It remains nice and taught but, you don't have to slam pin into the latch to get it to stay.  I believe I received that tip on the Forum (?).
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
