Author Topic: Wiring Connector Location  (Read 3300 times)
JimVillers
  • USA, VA, Virginia Beach
« on: March 01, 2013, 15:53:04 »
I have problem with my driver side tail light.  It has less than one volt at the tail light connector; the passenger side tail light works fine.
Does anyone know the location of connector #46 on the wiring diagram?  I have traced the wires into the soft top well (which I have not looked in because I have the hard top on and I haven't looked under the dash because of the under dash cover.  The voltage is normal at the fuse.
Jim Villers
Larry & Norma
Re: Wiring Connector Location
« Reply #1 on: March 01, 2013, 16:14:04 »
There is a connector block just above the kick panel by the hood(bonnet) release lever.
This applies to my RHD car so assume that it will be similar on a LHD car but opposite side.
This takes feed to the rear lights etc.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
