Author Topic: What is the best way to get the 45* angle coolant bypass hose on?  (Read 3461 times)
ncsurfer
Hi Guys,
I have everything off of the front of the engine on my 280SL, including the A/C- generator bracket. I have replaced the water pump and I am also replacing all of the hoses, belts, etc. I removed the thermostat housing off by cutting the old bypass hose off. Now I am trying to put the thermostat housing back on with the new bypass hose, but having trouble getting the hose on because of the two long bolts that the thermostat housing has to go over before being bolted down. Would heating the bypass hose in hot water help make it more flexible? Thanks for any help.
w113dude
Re: What is the best way to get the 45* angle coolant bypass hose on?
« Reply #1 on: March 09, 2013, 00:01:34 »
Soak the by-pass hose in hot water for a few minutes then rub the lips of the tube with a bit of grease, it will slide in without much effort.
ncsurfer
« Reply #2 on: March 09, 2013, 00:22:54 »
Thanks, I will try that.
