Author Topic: 62 MBZ 220se coupe fuel injection pump installation  (Read 11640 times)
thecarappraiser
« on: March 09, 2013, 00:51:55 »
Hi guys, i recently bought a 62 220se coupe 4 speed with factory sunroof and a/c. The old girl has been sat in a garage since 1975. The fuel injection unit is no good, but i picked up a used engine and trans complete with a supposedly good fuel injection unit.
Question is how do i set up the pump for installation, the pump turns 4 times for a complete turn. I have the engine timing set at TDC and i want to try and install the other fuel injection pump. Its the 2 plunger pump not the 6 plunger like on my 230SL. Any ideas ?
thanks
neil
drmb
  • New Zealand, Waikato, Te Awamutu
Re: 62 MBZ 220se coupe fuel injection pump installation
« Reply #1 on: March 09, 2013, 03:54:30 »
Align the timing mark on the inj. pump ( missing spline with the mark on the plate near the splined shaft ) then engine at TDC either firing 1 or 6 and install the pump
The pump supplies fuel to 3 cylinders at a time so it doesn't matter if it is firing 1 or 6 when installing inj. pump.
Mercedes Restorer.
1969 280sl 050 whte Blue interior
1996 E320 Cabrio
1963 220se 111-023 cabrio, red,black interior.
1967 Morris Cooper
Lloydmarx@xtra.co.nz
thecarappraiser
« Reply #2 on: March 09, 2013, 04:57:17 »
great thanks !  ;D hopefully i will have her running this weekend
thecarappraiser
« Reply #3 on: March 11, 2013, 19:53:01 »
got her all fired up and she's is alive !! awakened from a 38 year slumber, now i have to go through all the cooling system and replace rubber hoses
« Reply #4 on: March 11, 2013, 23:24:43 »
You were lucky to get it running that easily. That FI system is one of the most difficult to get working properly.
thecarappraiser
« Reply #5 on: March 12, 2013, 04:08:56 »
yes it was more luck than judgement! but i will take luck everyday of the week. I will get the rest of the mechanicals running as they should, see how she drives then start a bit of restoration with new seat covers and carpet for starters, and maybe back to the original white colour with a navy blue, or dark metallic grey roof color. Has to be pretty rare with a 4 speed, sunroof and ac.
« Reply #6 on: March 12, 2013, 13:57:20 »
Four speed and sun roof are not that rare - I had one back in the 80's and a 250SE with the same set up 10 years later. Both were euro cars.
 I would do paint first but maybe your interior needs that work now.
