I have a 1971 280SL Automatic.
Recently the cable for the neutral safety switch came loose. I tracked it to where it connects to the shift linkage area under the car (very tight area and hard to get your hand into. Turns out that the "c" clip was missing. The only way I could reconnect the cable was to disconnect the cable on the switch on the firewall. Once I connected the cable at the shift linkage, I could not reconnect at the switch end, even with the screw adjustments at the switch end of the cable.
Can someone please tell me detailed instructions on the proper way to "replace, ect." this cable. Then, what is the proper procedure to ensure that the safety switch and reverse lights are in order? Note: the Haynes manual is very weak in this area.
Thank you!
Bob Possel
Memphis, TN.
1971 Light Beige, Cognac, 82k miles
