Author Topic: Brake Master cylinder  (Read 3820 times)
« on: July 12, 2004, 08:22:35 »
I have a query regarding the connections to my TMC (Tandem Master Cylinder).
All references are taken from 'BBB' (Job No. 42-3a)
Page 1 is headed 'Tandem Master Cylinder' and describes the 1st, 2nd and 3rd version TMC's. My car is an early (manual) 230SL and was originally fitted with a 1st version TMC, which has the front wheels connected to the rear pressure chambre (push rod circuit) and the rear wheels connected to the front pressure chambre (floating circuit). I am replacing this with a 3rd version TMC which is usually connected opposite to this. The 'BBB' states that a 3rd version can be used instead of a 1st version but that 'the brake circuits are connected the other way round'
So does this mean if I use a 3rd version on my car the front pressure chambre is connected to the front or rear axle?
Sorry this seems a stupid question but I've sat and puzzled over this for ages.
Many thanks.
Kieron.
230SL 1964 (manual steering & g/box)
Re: Brake Master cylinder
« Reply #1 on: July 12, 2004, 08:25:04 »
Sorry this should have gone on the Tech Forum not 'Events'
Kieron.
« Reply #2 on: July 13, 2004, 08:53:51 »
Hi, Kieron,
My '65 230sl is plumbed like version 3.
The front vertically down facing port takes the left front wheel line while the one pointing @ 4 o'clock takes the line to the  right front wheel. Note the ports are different diameters to compensate for the long/short brake lines.
The single rear port takes the line to the rear wheels.
Hope this helps
« Last Edit: July 13, 2004, 08:54:47 by naj »
