Author Topic: W113 230SL auto gearbox issue..  (Read 3097 times)
Micker747
« on: March 15, 2013, 18:08:12 »
Help,
I just bought a 67 230SL, but on the way home in the snow (sorry) it suddently went out of gear and the speedo died at the same time. After stopping i could only go in second gear, disregarding if 2/3/4 was selected. In 2, 1-2 works, but that's it. Oil level is fine, no leaks. It happend cruising at 3000 rpm.
Thanks in advance guys.
Mike
drmb
  • New Zealand, Waikato, Te Awamutu
Re: W113 230SL auto gearbox issue..
« Reply #1 on: March 15, 2013, 18:29:54 »
The gears in side the rear transmission housing that drive the rear oil pump and speedo will be stripped.
Can be repaired by removing rear drive flange and rear housing.
Mercedes Restorer ( retired )
1969 280sl 050 whte Blue interior
1996 E320 Cabrio
1963 220se 111-023 cabrio, red,black interior.
1967 Morris Cooper
Lloydmarx@xtra.co.nz
Micker747
« Reply #2 on: March 15, 2013, 22:38:31 »
Thanks drmb, I really appreciate your help
so I will need to buy a new gear set. Any other parts required? Is there a Mercedes W113 PDF catalog avaliable where I can see the parts I need?
Could you please point out the parts here: http://www.niemoeller.de/w113/B042.html
Cheers
Mike
« Last Edit: March 15, 2013, 22:50:59 by Micker747 »
