Author Topic: Column switch wiring picture please  (Read 3042 times)
jedwards
« on: March 29, 2013, 10:01:33 »
Hi, I have an early 250SL and I am hoping someone might be able to help me with a picture of the wiring onto the board of the column switch?
Mine seems to have been "fixed" by someone previously and wires are very poorly soldered.  When I test the switches outputs at the male connector end, I have no switching at the pins for headlight flasher, windscreen washer and I only have 1 speed only wipers.  Turn indicators are OK.
I suspect that the wrong wires may be soldered onto the wrong terminals points,  but without an image, I cannot se where are supposed to connect.
Can anyone help?
Larry & Norma
Re: Column switch wiring picture please
« Reply #1 on: March 29, 2013, 12:21:43 »
Technical manual under 'steering column switch' shows some info.
Larry Hall (Gnuface)
2023 Ioniq6
2005 C230
