Author Topic: Clutch Pedal Woes  (Read 4616 times)
Clutch Pedal Woes
« on: July 14, 2004, 06:19:24 »
Folks,
Just got the SL back from the shop doing the state inspection. I had them install new clutch master and slave cylinders, as well as a new hose. Now the pedal scarcely comes up from the floor and, of course, the car is harder to shift than when I took it in. What did they do wrong, and is there something I can do to fix it?
Frustrated John
John Livingston
Newport News, VA
1968 280SL 4 speed manual
Re: Clutch Pedal Woes
« Reply #1 on: July 14, 2004, 06:43:09 »
Sounds like it needs to be bled properly. Connect the slave bleed nipple to the right hand front brake caliper and pump the brakes. If you do a search you will find it was discussed recently and accurately !
Good luck !
'03 CLK Kompressor
« Reply #2 on: July 14, 2004, 16:16:06 »
Thanks, Ben. I have to sheepishly admit that I was just outside putting the front up on ramps and got the pedal to pop out to normal height by just putting my foot under it. I seem to remember a post somewhere about part of the pedal assembly that needs lubing now and then. Perhaps that's all it is. I did find the bleeding post (no obscenity intended) you mentioned and will file that for future reference, should it not be just the pedal.
John
Good luck !
'03 CLK Kompressor
John Livingston
Newport News, VA
