Author Topic: Recent Brake Work  (Read 6859 times)
Recent Brake Work
« on: March 31, 2013, 21:24:33 »
Just replaced four hoses, rear disks and pads.  Rear brakes seem to be dragging now, not disengaging.  Please shed some light on this.  Thanks!!
« Last Edit: March 31, 2013, 22:37:46 by hauser »
w113dude
Re: Recent Brake Work
« Reply #1 on: March 31, 2013, 23:23:07 »
It's possible your hand brakes may be stuck in locked position.
« Reply #2 on: April 01, 2013, 02:26:51 »
No.
The hand brake is not the problem.  Today after going for a drive I noticed that it was dragging as I pulled into my driveway. After the car sat for a few hours the problem was gone.  It did return when I took it out a second time.  The pedal seems to get harder to press with each use.
« Reply #3 on: April 01, 2013, 02:42:52 »
You might try manually (with a lever) pushing the pistons back in the brake cylinders, then pressing the brake, the pushing back in, a couple of times. When my pads dragged it was the pistons not moving freely in the calipers. Did you use any copper or similar grease on the rear of the pads, where they contact the pistons?
« Reply #4 on: April 01, 2013, 03:27:38 »
Yes, good advice from Cees, exercise those caliper pistons!
« Reply #5 on: April 01, 2013, 19:37:55 »
I had the work done at a Bosch facility.
Kayvan
« Reply #6 on: April 01, 2013, 20:54:08 »
Check ur braided vacuum hose to booster
With all work your hose may be constricted or leaking; most hoses are very old
Neil Thompson
« Reply #7 on: April 01, 2013, 21:06:11 »
perhaps where they fitted the new pads in the calipers they didnt scrape out the old rust in the caliper slides and the pads are sticking. When they are stuck on, ie when hot, release the bleed screw - if the brakes release it is an hydraulic problem before the calipers, if still seized - either sticking pistons or pads (or the handbrake shoes which you say are ok)
neil
1957 190 SL RHD DB180 Silver
« Reply #8 on: April 04, 2013, 04:38:22 »
Latest update
The shop is going to replace the rear brake calipers (both) for the cost of the calipers ~$300 each with no labor charge.  Hopefully all will go well from there.
« Reply #9 on: April 09, 2013, 02:03:23 »
Update #2
Took the car back to the shop today.  It turns out that I am also in need of a new brake master cylinder and clutch slave.   ???
« Reply #10 on: April 09, 2013, 04:21:10 »
You win some, you loose some. What sort of condition was everything in before you started?
