Author Topic: Solenoid Test  (Read 2965 times)
gvillayandre
Solenoid Test
« on: April 06, 2013, 08:01:04 »
Hi all,
I am not sure if my double acting solenoid on the auto transmission is failing.
Can I test it applying battery power to it?
Ground to brown cables
Power to black to test kickdown first.
Power to white to test venturi switch.
Thank you for your support!!!
w113dude
Re: Solenoid Test
« Reply #1 on: April 06, 2013, 12:11:35 »
Yes, you can test it this way, brown ground, the other two wires should move it either direction.
gvillayandre
Re: Solenoid Test
« Reply #2 on: April 06, 2013, 13:16:02 »
Thank you!!!
