Author Topic: Rpm vs Mph - Automatic transmission  (Read 12581 times)
gvillayandre
« on: April 07, 2013, 07:46:54 »
Hi All,
I would like to compare my car performance related to Rpm and Mph.
Mine in fourth gear at 4.000 Rpm gets 55 Mph in a flat ride. No up or down hill drive.
Have anybody make this comparison?
Is there any table that compiles this info at standard?
Thank you!!
w113dude
Re: Rpm vs Mph - Automatic transmission
« Reply #1 on: April 07, 2013, 12:59:16 »
It should be closer to 3000 RPM at 55 MPH
georgem
« Reply #2 on: April 07, 2013, 19:24:53 »
Our 230 manual does 3000rpm for 60mph, 3500 for 70mph if that's any help. The speed I`ll vouch for as it was from a GPS, the revs were off the tach so no guarantee there
cheers
George McDonald
Brisbane
230 Sl
1973 VW Kombi Single Cab Ute
gvillayandre
« Reply #3 on: April 07, 2013, 20:11:32 »
Appreciated!!
I will record speed from 3.000 to 5.000 each 500 rpm and post.
« Reply #4 on: April 07, 2013, 21:18:12 »
You know it all depends on your differential gear ratio, which is stamped into a flat surface on the side of it. Lots of us have replaced original differentials with high ratios (4.08) with lower ones to reduce the RPMs at highway speeds. US automatics were typically sold with the 4.08 and I replaced mine with. 3.69 years ago. Reduces RPMs by about 10%.
gvillayandre
« Reply #5 on: April 07, 2013, 21:50:00 »
Thank you Cees.
I will check what is my car differential ratio.
Is this change expensive?
bogeyman
  • USA, NE, Omaha
« Reply #6 on: April 07, 2013, 21:54:30 »
In top gear, you should be about 2700-2800 at 55mph. If you are actually turning 4,000, my guess is that you are actually in 3rd gear?
No final drive ratio in the 113s will give you 4,000 @ 55mph in top gear.
Rick Bogart
1969 280SL Silver(180)/Green
1993 500E
1972 350SL
1995 E320 Cabrio
« Reply #7 on: April 08, 2013, 16:41:00 »
I changed my differential for, as I recall, around €500 including labor which was an ok deal because it took the mechanic most of a day. He kept the old differential.
« Reply #8 on: April 09, 2013, 02:48:28 »
You can compare your data with the ones in this graph:
« Last Edit: April 09, 2013, 02:53:07 by 66andBlue »
« Reply #9 on: April 09, 2013, 08:08:52 »
Good stuff for Tech Manual...
jameshoward
« Reply #10 on: April 09, 2013, 12:09:57 »
What a brilliant graph, Alfred. Thanks.
Can't wait to finish my car now.  Assuming we both don't disappear in a ball of fire and engine parts the potential looks great.
James Howard
1966 LHD 230SL
kampala
  • USA, CA, Beach Cities
« Reply #11 on: April 09, 2013, 13:17:24 »
Alfred,
You guys never cease to amaze ... much appreciated ... this is very nice.
250sl - later - manual
280sl - 1971 - Auto - LSD
71Beige280SL
  • USA, OH, Madeira
  • 1971 280 SL
« Reply #12 on: April 09, 2013, 13:42:50 »
Very helpful. Was there a standard Gear Ratio for 71 280SLs? Based on the chart, I believe mine would be either 3.69 or 3.75.
- 2024 Mercedes GLE 350
- 2024 AMG C43 Sedan
gvillayandre
« Reply #13 on: April 09, 2013, 16:17:11 »
Perfect!!!
Rolf-Dieter ✝︎
  • Canada, ON, London
« Reply #14 on: July 10, 2013, 19:27:32 »
This has to be the best car forum on the Internet ... Pad yourself's on the back fellow Members ... Well done ... I'm just blown away from the wealth of information on this site.
My 280 SL (1969) at 60 MPH is around 3,000 RMP at 70 MPH shows around 3,500 RPM (numbers are approx. ~ I will record more accurate numbers), I will keep an eye on it and make a comparison to the Graph ... Thanks Alfred
EDIT ---> Correction found out that my speedometer is out by about 8 KMPH (when compared to my GPS readout) so 60 MPH on my car speedometer is actually 88 KMPH on my TomTom GPS. and at that point I am at or near 3000 RPM.
« Last Edit: August 09, 2013, 20:04:04 by Rolf-Dieter »
Eminent
« Reply #15 on: August 09, 2013, 17:51:50 »
Alfred, i hope you don't mind.
I took your graph and convert it to Km/h.
Perhaps handy for the members with a Km tacho, like me.
I have a 3.69 spare diff wating for a swap with the 4.08 thats stil under my 280SE(L)
Rini.
