Author Topic: Backing Plate  (Read 2370 times)
AudioGuy
  • USA, MN
Backing Plate
« on: April 07, 2013, 18:12:27 »
Can the rear backing plate on a 280SL be removed without taking the rotor off?
Mark
1986 Porsche Carrera
Re: Backing Plate
« Reply #1 on: April 09, 2013, 19:53:39 »
I am pretty sure you have to remove not only the rotor, but the axle shaft itself.
jameshoward
Re: Backing Plate
« Reply #2 on: April 09, 2013, 20:10:57 »
If you can wait a few days and no one else pipes up, I'll let you know! (About to go there in reverse).
If you do have to remove the half shaft it's not hard. Do a search here for Joe A's technique involving a length of angle iron,  two bolts and a hammer works a treat in seconds. No puller required.
James Howard
1966 LHD 230SL
