Author Topic: Automatic Shifter Bushing  (Read 3771 times)
akessel56
« on: April 09, 2013, 01:40:11 »
So question, I have the shifter from my 280 sl out, (auto and new bushings on order)
My Bushing is stuck to the shifter, broke out of the connecting rod side, which is fine, but it brings up a question.
When rehooking this all up, which sounds tricky.  Which end to connect first - put bushing on the shifter first, or on the connecting rod first?
Thanks, Andy
PeterW113
  • United Kingdom, Blackheath, London
Re: Automatic Shifter Bushing
« Reply #1 on: April 09, 2013, 04:51:43 »
With the shifter assembly removed, I found it easiest to connect to the shifter first. I also used a length of wire as a "pull" to help guide the connecting rod to the transmission but it mat not really be necessary.
1968 MB 280SL, RHD Auto
1968 Lotus Elan +2
1962 Ford Thunderbird
2007 BMW 1200 GS
akessel56
« Reply #2 on: April 09, 2013, 19:07:23 »
the connecting rod to the transmission seems fine.  My issue is the shifter to the connecting rod.
it looks like bushing is on the left of the connect rod (which I swear are different from the pictures on the technical manual)
rb6667
« Reply #3 on: April 09, 2013, 19:28:09 »
Sounds like your bushing has shifted.  The bushing goes all the way through the long rod on both ends.  It "Pops" into the hole on each end.  If it is outside, you have found your problem.  When you replace these bushings, pay close attention to the which side of the bushing is facing in and out.
They will only work one way.  Don't ask how I know.  :o
RB6667
PeterW113
« Reply #4 on: April 10, 2013, 04:01:59 »
Could you have the connecting rod the wrong way round?
Not sure it's possible but just a thought.
1968 Lotus Elan +2
2007 BMW 1200 GS
