Hello Andy,
A couple of points to discuss ...
a)
I am also interested in the history of the early rough cast rocker covers and when they were phased out. Perhaps Achim with his incredible factory knowledge might know?
No...., Achim doesn't know that. Again he does not know that with these details ...
:'( They had this rough cast rocker cover quite for a while ... but 49er's former 250 SL had already a smooth rocker cover ...
b) Your alternator
All the necessary bushings in the mounting hardware of the early 230 alternator assembly are still available from the dealer. Some of the rubber is quite expensive but at least available. Fiddled also around with some selfmade rubber spacers first (I can't machine down teflon ...) but failed with that. So I went the way and bought new rubbers. It's worth the effort.
c) Your distributor
I am very surprised to see that your Pertronix unit went in easily. It did not at all in my case. However, I have got the 046 dizzy and you have got the earlier VJUR6 BR49T (= 040). But to me the both dizzies look exactly the same from inside (I have both distirbutors).
Quintessence: we had to modify the base plate of the dizzy and also the mounting bracket for the hall sensor a bit to make everything working properly.
Please, what was your order number? Maybe I got the wrong Pertronix set (the person who sold that to me is _the_ expert on this in Germany ...).
Well ...?
Unbelievable how much effort is necessary in every little not, bolt and bit of our cars ...
(fellow sufferer)
