Hi Tom, I am surprised that your car even starts with the csv disconnected. Perhaps it isn't that necessary in warm countries. I am certainly stunned that mine used to start so well when the csv was almost completely blocked. I certainly dont want to put you off putting your csv back in place. The test for the leaking solenoid is quick, easy and definitive. If your internal valve is leaking then its a different matter. The leak would presumably mean that your car would continually run rich. This problem is easily resolved as well by cleaning the filter (230sl only) and lapping in the valve stem which is only a ten minute job.
In the past two days I have concentrated on getting my exhaust back in the car. Quite a big deal with my bad back so I have taken things very quietly.
I consider myself fortunate to have a car with a very good stainless system installed. It scrubbed up almost like brand new and I even was able to make out a manufacture date of 1987 on a sticker on the muffler. I think if it were a mild steel unit I would be dealing with a pile of rust. I know its not original but the fit and quality is so beautiful I will forgive it. I am also very very thankful I have not got another costly replacement exercise on my hands.
Also spent part of the day finishing off the back end. Tightened the huge 36mm nut that hold the trailing arms on. Used a very long extension on my tommy bar. They are not coming off in a hurry.
Then went on to setup the lateral positioning of the axle relative to the body. That took quite a while to get mm perfect.
I also want to say a huge thanks to Pat, Naj and Dave who have all very generously sent me bits and pieces to keep me going. Its been really huge as I have been struggling with lack of income after the accident. Really appreciate it guys!!! Wish we all lived a bit closer so I could share a few cheeky beers with you all
