Cheers for that stick I will look into getting some. Trick is to find a supplier here in NZ.
The pitman arm tale was finished on the bottom of page 9. I ended up finding a 217 arm (rhd 113) in the UK. It took quite a lot of effort but worked out cheaper than bending. The installed arm sorted out all the issues with perfect alignment of the drag link arm and also misses by mm's the bracket that supports the gas steering shock and the subframe lateral support stay.
Just ticked it off the to do list and moved on with the next challenge.... and with these little puppies there are certainly quite a few challenges.
On the horizon I have:
1) Fix or replace the passengers door lock (anyone have a spare old unit I can buy. Just need the lock barrel)
2) Fix the wiring loom and reinstall
3) Put back together the Pedal Set
4) Install the brake and clutch lines (electroplaters has lost one of the lines)
5) Install the brake booster/master setup. (need to hand cut a rubber gasket for alloy to firewall spacer)
6) Repair and install the defrost vents
7) Put back together the rest of the air blower box
Will stop there as I will scare myself otherwise. As Dory from finding Nemo famously said 'Just keep swimming, just keep swimming'
