Author Topic: Question with front and rear oil seal and diff seal  (Read 5812 times)
erickmarciano
  • Canada, Quebec, montreal
« on: April 15, 2013, 19:36:11 »
Hi guys got 3 questions
The oil pan is off
1- for the front seal should I install the race and seal before I bolt the oil pan?
2- my rear seal is leaking does the top rear seal sit in oil or just slash oil from the pan?dont really want to remove the crank unless I have to.
3-I  see a puddle of oil where the rear pinion seal is on the floor.
I cleaned the area well and see traces of oil on the floor tunnel right above the pinion seal .with the car on the lift
It does not leak . Can it leak only when oil is hot?
Erick
1994 E500 W124
1971 280sl
1989 Porsche 930 coupe
1988 e30 m3
2001 ducati mh900
2006 ps1000
1962 Vespa GS160
Re: Question with front and rear oil seal and diff seal
« Reply #1 on: April 15, 2013, 22:48:02 »
Hello Eric,
 May be a bit easier with the pan off.  The rear of the crankshaft is not submerged in oil.  replacement of the lower half can make enough difference to keep from removing the crankshaft.
The rear pinion seal is the usual culprit for rear diff leakage, as long as the axle boot is ok. The rear diff oil fills only half of the housing. With the axles hanging down from a lift, the oil moves to the alxe tubes. Loss of oil from the pinion seal is minimal and usually not a cause of serious oil loss.
Ulf
« Reply #2 on: June 16, 2015, 12:16:52 »
I'm just reviving this topic as I too have discovered a leaking rear diff - to the point where I need to place a piece of cardboard underneath the car. Is this the pinion seal you mentioned?
http://www.theslshop.com/mercedes-benz-w113-pagoda-pinion-seal-ring-0049975646.html
Thanks in advance
Ulf
1965 230 SL in silver (DB180)
2008 Jaguar XF 3.0
2005 Mini Cooper
rutger kohler
« Reply #3 on: June 18, 2015, 04:09:18 »
Hi, although the pinion oil seal won't leak at rest, if you drive the car for some distance and it is leaking, the oil can blow back onto the diff casing itself and then drip down in your garage later, however this won't be a lot.  I have changed my pinion seal some time ago and the diff still leaks so it looks like a major for me, because I have not heard of many people have success with the split type rubber bellws replacement.  be delighted to hear from anyone who is happy with this fix.
1969 280 SL Manual gear shift
1972 280SE 3.5 auto
Ulf
« Reply #4 on: June 18, 2015, 13:59:37 »
That might be my issue as it is getting worse and worse, will look into it this weekend :-)
2008 Jaguar XF 3.0
2005 Mini Cooper
« Reply #5 on: June 18, 2015, 19:38:11 »
Another thing to check is the vent for the rear diff.  Due to the nature of the rear seals air can easily be sucked in as the diff cools but if the vent is clogged the diff can pressurize as it heats up.  Due to the rubber boot on the rear I would assume that this isn't as big a problem as a solid diff but it's worth a look.  It is just to the left of center(Side away from the boot) at the top.
rutger kohler
« Reply #6 on: June 19, 2015, 05:25:11 »
Hi, thanks for that, well worth checking.  I already did that but would recommend it to others who haven't.
1972 280SE 3.5 auto
