Author Topic: Parts Interchangeability list  (Read 4934 times)
jaxxonia
  • USA, CA, Woodland Hills
  • pagodaride@gmail.com
« on: July 14, 2004, 23:48:00 »
Just a public "THANK YOU" to Peter Lesler for
his Parts Interchangeability List. Efforts like his will
keep our cars going for future generations to enjoy.
Jackson
bob66542
Re: Parts Interchangeability list
« Reply #1 on: July 15, 2004, 15:43:18 »
thank u pete for faxing the list to me! i can now strip the 108 parts car and send the hulk on its way.-bob
65 SL 230 4-sp. purchase 12-08-03
admin
  • Administrator
  • USA, NY,
« Reply #2 on: July 21, 2004, 10:43:45 »
Here is the Parts Interchange list as compiled by Pete Lesler.
Pete has kindly given permission to post the list here. Neither Pete nor this Group guarantees the accuracy or completeness of the list.
Need Adobe Reader (available as a free download) to read the pdf file.
http://www.sl113.org/images/Parts_Interchange.pdf
Richard M, Admin
[Search terms: change exchange equivalent equivalence chassis similar M129 M-129 M130 M-130 engine ]
admin
  • Administrator
  • USA, NY,
« Reply #3 on: August 09, 2004, 04:05:29 »
Here are some additional exchange parts as compiled by Mike Heagney. Both donor cars were RHD.
Here are a few more parts to add to Peter's list. The following parts have been taken from either 220 Sb or Seb (W111). The Seb motor was port injected, from which I got the rocker cover and oil filler cap, and fits the 230 SL motor. This suggests motor was a 250, as the 220 Seb is apparently all manifold injected. Both cars are Euro R.H.D.
ELECTRICAL
Foot dimmer switch.
Fuel time lag relay
Cold start solenoid.
Constant speed solenoid.
Idle throttle switch.
Ignition switch
Various bakelite electrical connectors.
Wiring loom clips (various).
Blower motor switch.
Cigarette Lighter.
EXTERIOR.
Hub caps (for 230 SL)
Wheel stud bolts
Wiper arm nuts and washers.
"AUTOMATIC" badge to trunk lid (from a 230 S)
LIGHTS
Headlight orange blinker lens.
Headlight glass lens clips.
Headlight beam adjustment screws.
Headlight main beam reflector.
Main headlight bulb spring and lock plate.
UNDER BONNET (Hood)
From either 220 Sb or Seb port injected(W111):
Rocker cover and oil filler cap, (fits the 230 SL motor.)
Windscreen washer bag.
Idler arm trunnion bearing (220 Sb)
Front sub frame ....Version 2 only...220 Sb from # 49,856
...220 Seb from # 16,976...220 b...from # 23,661.
This includes upper and lower control arms. Not the springs. The swaybar mount on the lower wishbone is set at a slightly different angle.
INTERIOR
Flat spring steel in seats to repair broken spring steel.
Steering wheel, horn ring, horn pad and chrome bezel. (230 SL)
Carpet locating pegs to footwell.
Chrome cap to grab handles.
Blue plastic nuts to wood bows at dash....NLA.
Screws to chrome strip on A post inside door opening...NLA.
These fix the wood trim around the inside of door windows.
Fuel vapor reservoir in trunk.
Cheers,
Mike Heagney.
 64 230 SL in bits.
